K24 base map
Bull71
K24 base map
Post by Bull71 »
Hello All,(95 Civic Hatch)
I have swopped a K20A with a JDM K24A the car is running on the Hondata mod K20A ECU and Had to Change the Injectors off the K20 to the K24 due to one was bad I worried that it might be running Lean with the smaller injectors Should I Use and Load a Base map for the K24 and Chang the injector CC in the manager?
Please Advise
Re: K24 base map
Yes this will need to be completely retuned for the new engine.
stevegarage
Re: K24 base map
Post by stevegarage »
i believe stock injector still capable of supplying the right amount of fuel. please advice moderator.
