Air fuel sensor
Place your display templates here with a screen shot of it for previewing.
9queSt
Air fuel sensor
Post by 9queSt »
when you select the AF sensor in the display template, where does the ecu get the af reading from?
I have my wideband wired analog to b6. Also wired digital to the s300 digital source.
Re: Air fuel sensor
It gets the reading from the input to the ECU. You need to specify which input you are using in the closed loop advanced tab in parameters.
