K24z7 in car 1998-2002 take k24z7 ecu or use k20 cpu
phoenixgold
Post by phoenixgold »
sorry to ask but cant see any place where somebody take this engine in another car,el 1998-2002.
If flasspro can remove the key entry ,so the engine can work with the original cpu.
Or i need to use k20 cpu with flashpro.
In both way i need to buy hondata flashpro or k-pro .
if any can help.
Thanks all.
Sorry for bad english im french.
Re: K24z7 in car 1998-2002 take k24z7 ecu or use k20 cpu
I'm sorry, but we don't offer anything for this type of an engine swap. You will have to use an earlier engine and K-Pro for this type of vehicle.
phoenixgold
anyway i can plug the engine on another cpu ? or that can be done with some time ?
No, The newer engines use completely different sensors and trigers which are incompatible with older ECUs. You will find it much easier to just get a older engine and use the K-Pro.
phoenixgold
if i keep all the wiring and put it in a new car(ecu,dash,key and all the interior ),do you have flashpro for this ecu to be tuned on dyno ?
and any hondata module to remove the ignition key option ?
that way i can use my ecu and just wire all stuff in.
