set base timing with high idle
SPOOLIN
Post by SPOOLIN »
does the set base timing have any kind of limit to idle? just wondering...with a large cam we cant idle less than 1500 comfortably, it only makes about -5" vacuum. When ever i engage the set timing feature the car pretty much dies after a few seconds....so i have to rig the pedal just barely to keep it running to set the timing. Does this affect the end result on setting at 16*
any tricks to make it not die when engaging the set timing feature?
www.MSSRACING.com
9.29 | 6.20 | 167
Re: set base timing with high idle
When the set timing function is used it goes to a flat timing of whatever you set it to no matter the RPM.
SPOOLIN
Post by SPOOLIN »
Ok that's what I needed to read, thanks.
www.MSSRACING.com
9.29 | 6.20 | 167
stlegal
Post by stlegal »
SPOOLIN wrote:Ok that's what I needed to read, thanks.
http://www.youtube.com/watch?v=sGzxCCaxDjI
