Traction Control in SI 08 Brazilian
Ciclonvnz
Post by Ciclonvnz »
I have a Civic SI 08 Brazilian, I install the Hondata Traction Control, when looking at the wiring harness from the ABS sensors the colors do not match the ones in the tutorial Hondata, someone knows the colors corresponding to this version of vehicle?
Re: Traction Control in SI 08 Brazilian
Look in the factory workshop manual.
Neopoket
Post by Neopoket »
There are 4 speed sensors, one in each wheel. The wire colors for each sensor are:
Left Front: +B - white (Brazilian) or orange (US)
GND - Red (Brazilian) or gray (US)
Right Front: +B - Green (US and Brazilian)
GND - Red (US and Brazilian)
Right Rear: +B - Light green (US And Brazilian)
GND - blue (Brazilian) or white (US)
Left Rear: +B - Yellow (Brazilian) or blue (US)
GND - Purple (US and Brazilian)
Be carefully with left front because in braszilian car have 2 wire to abs with White and Red colors use a tester for check for continuity
Thanks for the information.
sebas22
Post by sebas22 »
Where is the Ecu Power IGP1 ?
for what vehicle?
