PRB Kpro V3 in UK EP3
05typeR
Post by 05typeR »
Hi guys,
I swapped over from my PRA V3 to a PRB V3 a few days ago, switching up the wiring was flawless and the car started and drove like normal, i drove to work (fuel light on) and the car parked for the entire day until evening when i started it the chk light came on. . .P0453 (91-2) Fuel Tank Pressure Sensor High Voltage. . .Now from my knowledge my UK model 2005 EP3 Type R does not carry an FTP Sensor but the US PRB ECUs will.
Why did the light take so long to come on?
Did this light come on because of my low fuel level (i drove many times with the fuel light on with no problems with the PRA KPro V3 with no errors)?
If i uncheck the "Emissions error checking" within the KManager will this solve this problem?
Will I have other problems because the car is a street car with a/c etc?
Re: PRB Kpro V3 in UK EP3
What ECU are you using?
Disabling emissions error checking should not cause any problems.
05typeR
Post by 05typeR »
Thanks...Spunkster
The ecu is a PRB kpro number is 12092...just left you guys a few weeks ago.
