Speed issues in datalog
Zoro2006
Post by Zoro2006 »
Seems that VSS (speed sensor) shows same value in datalogs even if I change speed in dash adjustment to 20%. Maybe it's possible to have correction in VSS sensor settings also ? Example
Known as Vaikis_
Re: Speed issues in datalog
This is correct as the correction factor is for the dash only and not for the ECU on a TSX.
Zoro2006
Post by Zoro2006 »
Spunkster wrote:This is correct as the correction factor is for the dash only and not for the ECU on a TSX.
maybe it's possible to add some correction under VSS sensor that in logs we could have same speed ?
Known as Vaikis_
mabo
Post by mabo »
Since your final gear and mb other gears r different from TSX then I guess you need to use special speed corrector \ calibrator between VSS and ECU. K-tuned offers such solution.
