RDX injector install. Cant upload or download Maps
Flip One
Post by Flip One »
I just installed RDX injectors. So i need to update the injector size in kpro for my car to run properly. When i plug the laptop into the ecu the computer recognizes the ECU says the drivers are up to date. but i cant upload download or datalog. it says the drivers are installed and it is online but. it says the ignition is off no matter what position the key is in. someone please help ECU Serial # 4532
Re: RDX injector install. Cant upload or download Maps
What vehicle is this in? HAve you relocated the ground properly? http://www.hondata.com/techk20ground.html
Flip One
Post by Flip One »
its 2004 Acura RSX-S w/ an 04 Type-R Transmission. the Ground has been relocated to the center head stud as recomended with the Hondata IMG install. but i was thinking about jumper int it to the battery ground cuz i was worried that it wasn't making a good connection before because my parking and licence plate lights flicker in unison.
Do you have the ground under the rubber gromet or on top?
Flip One
Post by Flip One »
on top and i was thinking that might be a problem. i get continuity when i check it with to meter but thats when the car is sitting stilll
Flip One
Post by Flip One »
Was this working properly prior to the injector installation?
Flip One
Post by Flip One »
Car was working fine prior to injector install ( Minus the cracked injector that is ) but i hadent acctually tried to upload download a map or Datalog in over a year. the only thing was the flicking Parking lights and licence plate lights. i had just thought they were flickering cuz they are not OEM bulbs but LED replacements
Post a picture of the engine bay showing all 3 of the main grounds.
