DTC P050A Cold Start Idle Air Control System Performance
FlashPro questions & answers specific to the 2010 CR-Z (US, Euro & Asia)
William5683
Post by William5683 »
I need help for anyone that has experienced this specific DTC while changing certain areas of their calibration. On my 2011 CR-Z I am running the latest Bata 1.4.7 release. When I updated I noticed a lot of new OBD2 error codes enablers under the MISC tab at the end of the Calibration, more specifically for the EVAP system, and another enable check that I can’t remember at the moment its name (at work). One of the changes I did on my calibration was I disabled the MAF sensor; I figured since I am using the MAP type tuning anyway that I could go ahead and uncheck it and just utilize the air temp sensor that is still being used by the ECU from that MAF already. I ran a data log and watched the sensors in real time and everything looks good. However after the ECU cycles awhile which usually takes the day sometimes shorter since I drive 178 miles a day. I only get this error in the morning usually or at a random time after the car has cooled all the way down and is started again. A couple of notes, the car has 70,000 miles on it, but the engine only as about 36,000 since the last one was replaced due to sucking up some water (storm with CAI) however the IAC still has 70K on it. Since then I have replaced the intake with a Takata unit. The EGR has been removed, block plate installed, and disabled, I plan to supercharge in the near future, so the EVAP is disabled currently since I have heard that if there is any type of leaks under boost the EVAP solenoid tends to cause a DTC to happen. Any thoughts? I really would appreciate it.
Re: DTC P050A Cold Start Idle Air Control System Performance
Try the return it to stock option and see if the problem persists, if it does then you need to follow the steps Hondata gives for troubleshooting that specific error code.
William5683
I will try that thank you
