NTK AFX Set-Up and Closed Loop
black4dr
Post by black4dr »
Hi,
I have a 1996 JDM ITR, an OBD2a-OBD1 jumper harness from eBay, and Hondata S300 V2 in a p28.
I am hooking up my NTK AFX following this:
http://www.hondata.com/techplxwiring.html
Will I need to remove these: R136 and R138 ?
Are there any negative side-effects if I do remove them?
Then I just cut my ELD wire on my OBD2a-OBD1 jumper harness and solder in my signal to the ECU and put some electrical tape over the other end of the wire?
I was reading this:
http://www.hondata.com/help/smanager/in ... meters.htm
And it seems I can run closed loop off of my wide-band? Is that true/does this work well? Does Hondata just convert the 0-5V signal ?
Re: NTK AFX Set-Up and Closed Loop
Yes you should remove them and there is no negative side effect.
YEs the closed loop with a wideband works very well.
black4dr
Post by black4dr »
Thanks.
Does it really matter if I ground the wide-band at the thermostat housing?
That is the best ground to avoid ground loops.
black4dr
Post by black4dr »
what are the chances of that happening?
What signs can I look for to know if it is happening?
If I ground it inside the cab, I don't have to extend the harness and run more wires.
