bought the v3 but now the engine cranks but wont start
Malkolm666
Post by Malkolm666 »
Hi Hondata,
I just upgraded my old kpro to the new v3, I did the registrestion, cleared the ecu (as usuall with a new kpro).
Im not new to this, have helped out 10friends the 2 last years.
I can upload files, Its online and ignition is on it says on the computer.
main relay/fuelpump goes on for 2sec. Everything seems right,
but when I crank the engine it won´t start, and it says rpm 0 all the time in Kmanager.
only sensors that moves is ect iat and tps(when I move the pedal), everything else stays at zero... (rpm, map, cam, etc)
PRB with serial 11753.
Re: bought the v3 but now the engine cranks but wont start
http://www.hondata.com/forum/viewtopic.php?f=12&t=3629
I have no record of this being an upgrade. This appears to be a new K-Pro installation in to an ECU that previously did not have a K-Pro.
Malkolm666
Its a complete new installation, my old kpro is sold.
Already found the problem, the big black junction connector C104, the IGP had a lot of oxide on the pin.
