dam missfires
rev hard
dam missfires
Post by rev hard »
im getting misfires from about 6k up...ive tryed adding uel...subtracting fuel....changed plugs...coils..but no luck..the car idle and drives along awsome....but after 6k it will start to miss ive just started street tunning it and wanted to clear this up before i hit the dyno
the setup is
84mm lsvtec
t1 spec web cams
s300
cpr
id 2000cc injectors
2 walbro 255's
bkr7e plugs gapped to .019
6766 turbo t4
2 tial 44mm wg's
any info would be great thanks
Re: dam missfires
IS this using an unmodified Hondata CPR harness? Dows this vehcile have a wire tuck or is it running any mil spec harness?
rev hard
Re: dam missfires
Post by rev hard »
factory oem harness...and the cpr un touched harness..all conections are soilderd ....but the stock igniter is in the dizzy with the coil removed...would taking the factory igniter out make a difference?
Re: dam missfires
Is this an oem distributor or an aftermarket one? You do not have to remove ANYTHING from inside the distributor.
rev hard
Re: dam missfires
Post by rev hard »
ok..i think i may have found the problem...tell me if this sounds right....when i hooked the 2 wires to the dizzy plug i soliderd them inline and didnt cut them( wasnt completly sure wat to do so thats wat i did) so...i removed the igniter and all the wires plugged into it and took it for a drive and now the missfires seem to be gone....is this because i didnt cut the wires and instead spliced into them?
Re: dam missfires
You should not have to cut any wires at the distributor. You depin the wires form the harness and then crimp on the supplied pins then put the pins into the connector and plug it back in.
rev hard
Re: dam missfires
Post by rev hard »
yes i understand...but there was a differnt plug on my dizzy/harness so your suplied pins would not fit....does that explain wat the problem would have been?
Re: dam missfires
We provide pins for both OBD1 and OBD2 distributors.
rev hard
Re: dam missfires
Post by rev hard »
yes i understand you do...long story....anyways for the last time do you think that would cause the issue? was the factory igniter robbing power from the system? causing the spark to be weak and miss at upper rpms?
Re: dam missfires
Anytime something is not installed as it is supposed to it can cause problems.
rev hard
Re: dam missfires
Post by rev hard »
ok thanks..well hopfully this can help somone eles if they ever do the samething
rev hard
Re: dam missfires
Post by rev hard »
ok...so it turns out the problem is still there...here is my latest map and log...you can see in the log were it starts to miss the rpms are choppy....im stumped
i also just noticed that at idle my tps is 24% and over 100% at wot.....would this cause it to do this?
rev hard
Re: dam missfires
Post by rev hard »
also using a jdm gsr basemap with a U.S p28 ecu...would that cause any issues?
Re: dam missfires
The TPS needs to read correctly , but that is probably a separate issue. Without knowing exactly how this is wired it is impossible to know if it has been wired correctly. Where did you connect the 2 grounds on the CPR harness?
rev hard
Re: dam missfires
Post by rev hard »
its wired as per instructions....the ground with the termial is on the thermostate housing with the oem ground...and the other ground is at the ecu at pin a23
