TSX TB Issues
ryno_rx8
TSX TB Issues
Post by ryno_rx8 »
I recently got an 07 TSX tb for my car (09 Si) and no matter what I try, i can not get the idle learn procedure to work. I still the get the fluctuation from 1000-1500, I have Flashpro now and my question is, will i still need to do the relearn or will the FP override that since it has setting for idle? Thanks. I tried searching and found no definite answer
Re: TSX TB Issues
Make sure that there is no vacuum leak, if the problem is mechanical and not tuning related then the FlashPro will not help.
ryno_rx8
Re: TSX TB Issues
Post by ryno_rx8 »
I double checked for vacuum leaks and didn't notice any. Only thing I can think of is when I do the idle learn, I was letting off from the 3000 when the fans first kicked on, gonna do it again and let them cycle on and off before I let it idle. Also, what do you adjust in FP to fix the rev hang issue?
Re: TSX TB Issues
Go back one step. Is the TSX throttle body equivalent electrically and mechanically to the Si throttle body?
ryno_rx8
Re: TSX TB Issues
Post by ryno_rx8 »
Hondata wrote:Go back one step. Is the TSX throttle body equivalent electrically and mechanically to the Si throttle body?
To the best of my knowledge it is equal with the exception of being 4-5mm larger. Plenty of people are running them, some have to ddo the idle learn, some get by without it somehow.
Re: TSX TB Issues
Does it work with a stock ECU?
ryno_rx8
Re: TSX TB Issues
Post by ryno_rx8 »
Yes. I have solved the problem. Thanks for your replies!
fryrice
Re: TSX TB Issues
Post by fryrice »
hey can you tell us how you resolved your problem so other members know what you did?
was it your tb that had a loose vaccum? or something else?
