Injection times
angelf1974
Injection times
Post by angelf1974 »
Why are fluctuations in the injection times? Is this normal?
Honda Accord CL9 (Spain)
Re: Injection times
Not normal. Seems to start at VTEC switch. We'll try the calibration in our car.
angelf1974
Re: Injection times
Hondata wrote:Not normal. Seems to start at VTEC switch. We'll try the calibration in our car.
Thank you. I will wait for your answer. I discovered it in the last datalogs, some time ago there are not this fluctuations.
angelf1974
Re: Injection times
Please, one more thing. Is it safe to use the car in these conditions?
Re: Injection times
Seems ok here (we can't test the exact calibration because we do not have an automatic). I would try FlashProManager version 1.5.0 and also check & clean your engine grounds, as some of the engine sensors are changing value at VTEC, which coincides with the odd behaviour.
angelf1974
Re: Injection times
Hondata wrote:Seems ok here (we can't test the exact calibration because we do not have an automatic). I would try FlashProManager version 1.5.0 and also check & clean your engine grounds, as some of the engine sensors are changing value at VTEC, which coincides with the odd behaviour.
My car is manual.
I will try the new version and check grounds, thank you.
Re: Injection times
angelf1974 wrote:My car is manual.
Sorry, it is indeed a manual calibration.
angelf1974
Re: Injection times
Well, I tried the same calibration but with FalshPro Manager 1.5.1 and everything remains as before.
The engine grounds seems to be ok.
Then I tried the base map calibration and works fine, no fluctuations. I think there is a problem with my calibration but I can´t discover it. It is always at WOT (in closed loop it is ok), and always in high cams.
Re: Injection times
Have you tried starting with a new calibration and importing the fuel and ignition tables from your current calibration?
angelf1974
Re: Injection times
Base map.
Base map + fuel tables
Re: Injection times
Can you import the fuel tables one by one to narrow down which is causing the problem?
angelf1974
Re: Injection times
Hondata wrote:Can you import the fuel tables one by one to narrow down which is causing the problem?
I have tried it, the fluctuations appears when I import the 25 degrees fuel table (high cam)
Another test, I have a old calibration and its datalog, it was ok but, if I load this calibration now then appears this fluctuations.
Could it be due to low quality fuel?
