Controls.Top = - Y in my display
Place your display templates here with a screen shot of it for previewing.
ketchu13
Post by ketchu13 »
Hello,
After a reload of my display template, all my controls are moved in Y axis..
Some controls.top are in négative value -y.
I can't edit directly with some text editor the display template file .
It would be great if Someone could help me to center my template.
I deleted the background image to reduce the file size... for posting here.
Act a fool !
Re: Controls.Top = - Y in my display
You will have to unlock the controls and then move the controls around where you want them, then save the display.
ketchu13
Post by ketchu13 »
thanks for your response,
but as I said in my first post some controls are in negative Y value.
Edit: Totaly in negative.
So I can't select them to move.
Edit: This is an old picture of the top of my display template before this problem
Act a fool !
If you ahve saved over the original file and it is now correpted then you will have to either start over, or remake the controls that are missing.
ketchu13
Post by ketchu13 »
ok thanks.
Il will delete this display file and remake it.
An object browser in the display template editor would be nice ;)
Act a fool !
