AFR and ignition behavior normal?
BMR
Post by BMR »
I am having a misfire at idle and I am not sure if the oxygen sensor is going bad or if I have another problem. Can someone confir if the bahavior in the attachment for afr and ignition is normal?
Re: AFR and ignition behavior normal?
The ignition is normal (see http://www.hondata.com/forum/viewtopic.php?f=12&t=16144).
The AF is slow to respond, which could be from a number of causes - incorrect o2 sensor, exhaust air leak, o2 too far down the exhaust, heater not working.
BMR
Post by BMR »
Hondata wrote:The ignition is normal (see http://www.hondata.com/forum/viewtopic.php?f=12&t=16144).
Thanks for the response. I thought that the ignition behavior was normal since I remembered it being that way in datalogs
I thought that the O2 reading was incorrect since I did not remember it being that way. I thought it would be linear instead of oscilating that much.
incorrect o2 sensor - I don't think this is the issue. I bought a new oem sensor initially when I did the swap. Could it be that is going bad?
exhaust air leak - the exhaust air leak would need to be in the header or exhaust piping, correct? I do not have any leaks so I do not think this could be the issue
O2 too far down the exhaust - I am using one of the common aftermarket headers. I don't think this is the issue.
heater not working - Would this affect the sensor reading even after the engine has warmed up or only at cold start up?
I believe this could be the issue. Is there a common heater avaliable recommended for use?
you cannot replace the heater. You have to replace hte entire sensor. A bad heater will act up at all times.
BMR
Post by BMR »
Thanks for your help
