RC1000 Injectors installed in an H22A.
ineedmoney
Post by ineedmoney »
Needing Help to get this motor idiling correct after installing RC1000cc low impedence/peak and hold injectors on an all stock H22A with the exception of an AEM C.A.I. ,Header , Three inch exhaust and Hondata S300 in a P28. Please keep in mind that i am unable to dyno tune cause there is none available where i reside! If there is anything i could possibly do to my parameters as in fuel trim or Whatever i'd appreciate it. i need feedback.
ineedmoney
Re: RC1000 Injectors installed in an H22A.
aint no one got any thoughts on this?!
Why are you using such large injectors on a basically stock engine?
ineedmoney
The original injectors I had on the motor were from a 1991 Accord. I bought those 1000's for $300. So that's what I'm working with! I just need them to work so I can enjoy driving the car again! If you got any tips my ears are open to suggestion!
You will need a wideband in order to properly tune the fueling. Make sure you are also using a resistor box or you will damage the ECU.
ineedmoney
Ive got a resistor box installed for the injectors! As for the wideband i saw through the site that Hodata uses PLX and FJO wide bands!Im considering purchasing one of these. Do you guys offer LIVE tuning srevices? The few tuners where i reside will only do AEM and not HONDATA for what reason i have no idea!!
No, we do not offer any tuning services from Hondata.
ineedmoney
Wow I thought you guy did. Thank you though!
