civic si 2006 problem
ep3K24lol
Post by ep3K24lol »
hello i got a civic si 2006 fg2 it doesnt came with the sensor so i install the sensors from a civic si 2008, everything works ok, i wire the traction control to EGRL pin, no errors nothing, but the flash pro shows -9% traction control over slip (from ecu) and it doesnt command when the car is sliping.
these are the datalogs.
Re: civic si 2006 problem
What sensor was your vehicle missing? All 2003+ Hondas had ABS.
From the datalog the wheel speed sensors are (mostly) working and the slip calculation looks correct. However the ELD voltage is not doing anything.
So:
- check you FlashProManager version
- find and fix the problem where the RF speed sensor is getting spikes in speed
- check you have the TC set up and wired for active speed sensors
- use the TC test output to check the wiring to the ECU EGRL input
