need help with this cal asap
touch
Post by touch »
car running lean and when I unplug the laptop the car shut off
Re: need help with this cal asap
Check your grounds in the engine bay as it sounds like soemthing is not connected properly and if this continues you will damage the K-Pro and or the ECU.
touch
Post by touch »
my ground its ok. when I run a stock base map car run fine but when I run that map it act up running lean and shut off not sure if its the map or not
IF another calibrations works and that one does not, stop using it and use the calibraiton that does work.
