Since my car has been tuned there has been a dip around 4200 -4700 rpm.
My tuner tried everything to get this away but did not succeed. He told me this is caused by the 16 valves effect.
Though VTEC engages at 3500 in open loop, torque does not mount immediately after it.
Not the best map Ive seen, but certainly not the worst. Could it be tuned out? Maybe...but its not worth messing with a tuned map. Especially with no log or dyno AFR reading.
02 RSX Type S (sold)
11 TSX Tech (daily)
Hit me up for free Hondata Help. Over 4K downloads on my famous GSR Tune!
Dyno AFR was tuned, but just not showing on the map, AFR was 12,8 above 3000 rpm and 12,5 near max RPM.
What can be better in your opinion? Do you believe the dip can be removed by mapping or is it a setup limitation?
AFR was fine around 4500 rpm btw. And what about oil consumption, can it be caused by this map? I have a consumption of 1 liter every 2000 km on high load on the engine i have to admit.
If u think u can make it better and gain higher HP on 4500 rpm and above 8000 maybe its worth it for me to make some logs.
But I dont have a wideband sensor since i have PRA ecu.
13.5 is a little high for my taste (my car made best power in the high 12s on the dyno) but other than that, his suggestion could work. It will require you to put some work into your low cam tables though and without a dyno theres no guarantee it would work.
Post a log with the new cam angles and the AFRs logged and fixed.
11 TSX Tech (daily)
But i believe my cams are at 30 degrees around those rpms.
I'll check when im home.
We believe the dip is from the 3 inch.
But i can test, normally i should feel the difference.
