Is K-pro available for 37820-PNN-Z52 ?
ET1
Post by ET1 »
Hi,
As the title say, is there K-pro or any other Hondata option available if I have the below ECU?
37820-PNN-Z52
Did a conversion from a K20A3 to a Type-R K20A and piggy backs just doesn't cut it.
ps : The car currently using a 5-speed Auto
Thanks in advance for any help.
Re: Is K-pro available for 37820-PNN-Z52 ?
The only ECUs which can be used are PRB-A03 through A08, PRB-305, PND-A0X, PNF & PRA.
ET1
Post by ET1 »
Hondata wrote:The only ECUs which can be used are PRB-A03 through A08, PRB-305, PND-A0X, PNF & PRA.
Thanks for the reply.
Another question, these ECUs listed are only for manual transmission right?
Meaning, even if I get one of the listed ECUs, it will not work with the current auto tranny setup correct?
That's correct.
