Use wideband sensor as a Closed Loop
Michaelek9
Post by Michaelek9 »
Is there any way to use the LC-1 as a closed loop input?
Re: Use wideband sensor as a Closed Loop
No.
Michaelek9
okay! can i use oem sensor wide band on my PRC ECU? If not.. what type of O2 sensor can you recommend
for close loop input?
The factory wideband will work with the PRC ECU.
Michaelek9
Can you give me the part number of the OEM Wide band o2 sensor Please!
How many electric wire does it have 4 or 5 ?
Can I use the existing line from the primary narrow band o2 sensor?
What vehcile are you referring to?
Michaelek9
Spunkster wrote:What vehcile are you referring to?
K20a from dc5 Jdm with kpro prc ecu swap to ek hatch.
Michaelek9
I'm running on the original Primary O2sensor of dc5 engine. I want to remove the LC1 since it is for data logging only.
Is it true that dc5 jdm o2 sensor is a wide band?
How to verify a wideband O2 sensor regardless of wires number?
Yes it is true. They are all 4 wire sensors. YOu can order this from any Honda/Acura dealer. It is the prmary AF sensor.
