What happend to Stage 1
PRCIVIC
Post by PRCIVIC »
:( I guess this is for Hondata to answer. What happend to stage 1 feature of the system. The way I understood it was that with a stage 4 you would be able to program a single chip ECU without using the interface box :?:
If you don't drive a HONDA you ain't driving!
AndyE
Post by AndyE »
Stage 4 users can only program stages 2/3/4. Stage 1 was a feature-stripped ROM that Hondata provided at a much lower cost. It didn't require an interface box because it didn't need any external inputs or outputs.
All ROMs created with a Stage 4 user's ROM Editor program still require the use of a Hondata interface box, otherwise you're limited to 4k rpm and 1 psi of boost. Otherwise a Stage 4 user could just churn out ROMs for all their buddies with modified fuel/timing/VTEC/rev limiters, for the mere price of a PROM chip.
-Andy
'99 EBP Si
S200 w/everything|12psi JRSC|Heatshield
AEM CAI|Kamikaze headers
Custom (quiet) 2.5" exhaust
Quaife LSD|JUN 9lb flywheel|ACT XTSS clutch
Eibach Pro-Kit/KYB AGX
Full polyurethane bushings/mounts
OZ 16x7 Superleggera + Sumi HTR Z II
Stage 1
Stage 1 never existed. We developed the circuit but then held the release until V3 was released. In the near future a product similar to the stage 1 will be released.
AndyE
Post by AndyE »
What did you guys call the modification where you just reprogrammed the vtec point and rev limiter? I thought that was Stage 1...
Used to be listed on your web site, but that was well before the s200 was released.
Stage 1
This was something we sold just for the PW0 but stopped selling the stage 1 once piracy was a problem. I think the last one we sold was in 1999. The stage 1 was developed about 1 year ago, but unfortunately the marketing division got word of it from the r&d division before the stage 1 was finished, and subsequently it was advertised before it was finished. In the meantime V3 came along, and the stage 1 was delayed for about 10 months. Now the stage 1 is called a s100, and will be released soon
PRCIVIC
S100
Post by PRCIVIC »
Ok so what will the S100 bring to such of an advantage that the S200 full owners meaning = to Stage 4 would be able to do for the S100 owners.
Will it use an interface box? Or will it be a Chip Mod?
