I though flashpro fixed that darn rev hang issue??
Z-Type
Post by Z-Type »
I'm using the civic-si-rrb-5-skunkhdr tune cause its the closest to what I actually have. I actually have an injen CAI/ Megan racing header/ no cat/ Megan racing exhaust. I noticed a substantial difference with the tune and how the car runs. But I still have that revs hang issue. I don't think it actually got any better. I did find in the calibrations tab that "purge evap" is enabled. Do I want to disable that? My buddy that works at Honda says that's why these things hang so bad, cause they purge when you shift. Am I missing something to this? Does anyone have a tune closer to what I have done to my car?
Thans guys
EDIT: I also found this VTEC window RPM and it ranges from 4259RPM - 5900RPM. What does that mean?
Re: I though flashpro fixed that darn rev hang issue??
Specifics on how the VTEC window works can be found at: http://www.hondata.com/help/flashpro/vt ... htsub=vtec
You can try making adjustments to the fuel overrun cuttoff settings and that should help with the rev hang. It does not have anything to do with evap purge.
Z-Type
Post by Z-Type »
Gotcha, thanks a bunch. I'll do some more experimenting.
