AEM wideband hookup into 2012si ecu??
Sleepingpanda
Post by Sleepingpanda »
I was wondering if its possible to wire the AEM wideband into the ecu so I can datalog with it. Like the 8th gen into the b29 pin.
So does anyone know if that's possible with the 2012?
Re: AEM wideband hookup into 2012si ecu??
YEs it has the same options under closed loop, Lambda in the calibration window.
Sleepingpanda
Spunkster wrote:YEs it has the same options under closed loop, Lambda in the calibration window.
I don't mean in the program. I mean physically on the 2012 ecu. Does it have an empty terminal that can be used for wideband sensor input.
YOu can see the inputs that can be used in the software. ELD or ECT2 can be used.
Sleepingpanda
Spunkster wrote:YOu can see the inputs that can be used in the software. ELD or ECT2 can be used.
Okay I'll try to get a pin out of the ecu then. Thanks.
dghboy
Post by dghboy »
any luck on the pinout I would like to do the same B29 was for the 8ths but noone has confirmed it will work for the 9ths..
A44 is ECT2
A34 is ELD
dghboy
Post by dghboy »
thanks
jun1or
Post by jun1or »
When using the AEM wideband's output, don't forget to set the "Wideband Lambda" table (volts vs lambda), as the default values need to be modified. Also be sure the AEM sensor ground is grounded to ECU ground (vehicle specific). See the very last post in this thread regarding an example to the table settings...
http://www.hondata.com/forum/viewtopic. ... 761#p71046
Just FYI.
Mike
