DOHC ZC Base Map
mksch666
DOHC ZC Base Map
Post by mksch666 »
Looking for a p29 base map to start tuning a DOHC ZC. Any help would be appreciated.
Re: DOHC ZC Base Map
Click New Calibration then select the d16A1 calibration
gregoyo1
Post by gregoyo1 »
I just uploaded this calibration on my p28 s300 v2 software 2.2.7. Running a d16a1 in a 1978 civic.
It feels like it will only accelerate or decelerate.. I cant get it to smooth out.. cant pass emissions load test this way..
No dtcs other than vss not installed so its disabled and launch control turned off..
Is the a completely stock pg7 base map I can use to compare with?
I just converted from obd0 pg7 to obd1 p28 with s300 v2, locash ecu adapter, td43u distributor, new 4 wire o2 sensor...
Any help would be greatly appreciated
You cannot compare a OBD0 ECU map with an OBD1 map, t hey are completely different. That was a tuned calibration for a D16A1 in an 88 Integra.
You may need additional tuning on the dyno especially at part throttle.
gregoyo1
Post by gregoyo1 »
Got it thanks.
I loaded the p28 calibration and it runs great!
Good for getting groceries and driving grandma to work.
Just had to disable vtec and runs great even passed emissions!
Thank you
gregoyo1
Post by gregoyo1 »
With the d16a1 tune I definitely could tell has much more power but hard to drive unless dyno tuned as recommended.
keto06
Post by keto06 »
Did you try the map in this thread?
viewtopic.php?f=20&t=17111
02 RSX Type S (sold)
11 TSX Tech (daily)
Hit me up for free Hondata Help. Over 4K downloads on my famous GSR Tune!
