Parts for Boost Control Application
hipowerracing
Post by hipowerracing »
hi guys need some help
i got a S300 on a P28 and im about to solder the resistors and and transistors for the ecu.
however i would appreciate it if someone can give me a details of the following as in what parts to buy from the electronic shop
Large Resistor Specs?? or Part number??
Small Resistor Specs?? or Part number??
Diode Specs?? or Part Number??
any help will be appreciated..
Thank you in advance
Re: Parts for Boost Control Application
We dont' give out the part umbers, but you can purchase all the components in a kit through any dealer for $10. This is to assure you get the correct parts and do not damage the ECU with improper components.
