KPro V3 Daughter Board Communication error Low when cranking
Savtec
Post by Savtec »
Acura RSX premium 2004 100% Stock 120 000 km
I have bought my acura installed the new battery AGM . I have done over 6000 km without any problem with stock ecu .
I have installed the Brand new (k-pro V3) and cheq engine light on code appeared. (Daughter Board Communication error Low when cranking)
I clean all ground cheq charging alternator (14.4v-14.5v)
Re: KPro V3 Daughter Board Communication error Low when cran
Was the KPro installed before or after the battery? Is the battery relocated? What is you battery voltage when cranking?
Check the battery voltage when cranking at the ECU.
Savtec
Post by Savtec »
k-pro was installed after the battery i run 6000km with battrery with ECU Stock no problem .
No relocate RSX 100% STOCK
Cranking voltage in ECU 9.80v -10.45v
Cranking voltage in battry 11.45v 11.80v
Idle @ 850rpm 14.02 V Charging in battry same in k-pro (not load)
@3000rpm 14.07 V
Full load @850rpm 12.51V @3000rpm 12.96V
A/c with fan max
Fog
Defrost
Light + high beam
radio
Injector ground : Clean
battry to body ground :Clean
battry to transmision ground :Clean
Body to Mounts Ground : Clean
Wiring ground 100% OEM
Savtec
Post by Savtec »
I will do the same test with a standard battery .
I'll come back with the result.
Changed ground clear code and test 2 weeks
