base rsx hondata reflash.
hdksb2
Post by hdksb2 »
Hey guys so this is my question : i have a base rsx with the prb intake manifold and i want to reflash my ecu, so wish are my options can i use the base rsx ecu reflash or i have to get a 02 civic si ecu a reflash it ???
Re: base rsx hondata reflash.
For this you would have to get the K-Pro to proerply tune it. A reflash will not work if you have swapped manifolds or done anything more than an intake, header and exhaust.
hdksb2
Post by hdksb2 »
Spunkster wrote:For this you would have to get the K-Pro to proerply tune it. A reflash will not work if you have swapped manifolds or done anything more than an intake, header and exhaust.
So the pnf ecu can't be reprogram to work into the rsx??
There is no reflash for this.
