knock sensor
jeffyjeffracer11
knock sensor
Post by jeffyjeffracer11 »
I have a 1993 Honda del sol s with a d16z6 and p75 ecu with s300, precision 6262 turbo 25psi. is there a way to wire in a knock sensor since I don't have one or will I have to go with an aftermarket setup? If I can't wire one in does anyone have any recommendations on a knock detection system?
Re: knock sensor
You cannot use a knock sensor with the ECU you have. YOu would have to use a P30, P72 or P61 ECU. The other option is to get the J&S Safeguard which is a stand alone knock protection device.
