tps problem
Knox
tps problem
Post by Knox »
Hello guys,
I have a problem with my tps sensor.If you checked my datalog, you will see that tps sensor reading is 52% at 8620rpm while i'm at full throttle. I changed tps with second hand oem one, now it is better but again same problem (this is with new tps sensor before its worse than this reading). Is it 100% tps problem because i tried 2 tps sensor and both makes problem (both of them are old) or can it be wiring problem? (my tps sensor's socket disconneted because of tight fitting and i rewire it before).
Thanks for comments.
Re: tps problem
IT is either a TPS or throttle body problem. Are you sure it is opening completley?
Knox
Re: tps problem
Post by Knox »
Spunkster wrote:IT is either a TPS or throttle body problem. Are you sure it is opening completley?
So, i think tps is the problem because when i'm at full throttle and have this problem when. Check my datalog power vise it feels ok, so i think it is tps.
Thanks for great support hondata & spunkster.
