s300 green light goes out when ignition is turned on
frankieboost
Post by frankieboost »
I've been getting this problem lately when ignition is turned on i here fuel pump turn on and the green light on the s300 turns on then flashes green quickly then shuts off before starting the car . i keep turning off and on ignition until the light stays solid green to start the engine any suggestions whats going on .
thanks
frankieboost
Re: s300 green light goes out when ignition is turned on
anyone run into this problem ....
Who socketed the ECU?
hoorah
Post by hoorah »
I had this happen. Go to your vault and set up a password. Took me forever to figure that out since it had been a while since I updated my software.
Hope that helps.
frankieboost
Spunkster wrote:Who socketed the ECU?
my tuner chris miller racing, he also told me it could be bad grounds or power
It sounds like it could be a socketing problem. I would have the ECU checked to make sure the soldering is good. Also make sure that the main capacitor was replaced as it could give intermeitent faults before a complete failure.
