speed sensor
zzzz
speed sensor
Post by zzzz »
Hi
Could you help me out i need a wiring diagram for hall effect speed sensors, in the help there is a diagram for inductive and active sensors but not for hall sensors. Also do I need to use some sort of pull up resistor?
Re: speed sensor
It depends on the sensor - what sensor are you using?
zzzz
Re: speed sensor
Post by zzzz »
Re: speed sensor
That sensor is 3 wire - power, ground and signal.
- ground connect to the same ground as the traction control unit.
- power is 4.5V to 24V, so you can power it from from the same power source (12V) as the traction control unit.
- signal connect to the positive side of the wheel input
The sensor has a 40mA output which is a current sink. That means that you need to use a pull up resistor between the sensor power and sensor signal. The resistor should be somewhere between 370 ohms and 10k - I would use a 2k 1/8W resistor to start with, and then go to lower values if you start to get noise on the signal.
zzzz
Re: speed sensor
Post by zzzz »
Will let you know how it goes.
madmazturbo
Ecu colour connections
Post by madmazturbo »
Hi
Can you assist me a little further for cable colours for the ECU for terminating the traction control please:-
traction control cables are :-
L+ (red)
- (black)
ELD (orange)
ECU is :-
(E connector) 15 ELD - (?)
(A connector) 3 IGP1 - (?)
(A connector) 5 PG1 - (?)
I am fairly certain i could figure it out but would be nice to know exactly what the actual colours i am connecting to on the Kpro A-conector and E-connector
Cheers
Re: speed sensor
Do not go by wire color at the ECU, go by pin position as it is most accurate way of doing it.
madmazturbo
Re: speed sensor
cheers, i think i have sorted it, basically i have no pin in the eld 15 for my plug. It is part of a hybrid racing adapter, any ideas where i can get a pin from in short notice?
Re: speed sensor
You might try Xenocron Tuning, as I believe they sell individual pins.
