d16z6 n/a fully build with comp cam 59300 76mm p29 pistons.
biggied16king
Post by biggied16king »
I have a build d16z6 with crower valve train ( flat heads ), comp cam 59300, 76mm p29 pistons, 255walboro fuel pump, dsm 450cc, msd spark plug wires and coil, 0.30 cosmetic head gasket, skunk 2 pro series IM and TB, JG header. I need a good base map until I get it tune. Its running good but its knocking cause its leaning and if anybody can help me out that would be nice. Big thanks!
Progress
Re: d16z6 n/a fully build with comp cam 59300 76mm p29 pisto
Post by Progress »
You cant use DSM injectors on a S300 use RC or ID. What kind of knock do u hear.
tuning upon request
347-989-5028
9.23@167 B18C street/track tuned
HP unknown
biggied16king
you sure I cant use dsm on a s300? will it only knocks when the motor is hot ( normal temp ) runs good and everything but when your slowly hitting the gas a little bit then you can hear the knock , no knock when WOT. my buddies tell me its a lean knock so I just need a good basemap b4 my tune
Progress
Post by Progress »
That what they say.
tuning upon request
347-989-5028
HP unknown
You can use them, but they are not recommended as they are known to be unreliable.
biggied16king
oh ok thanks then. but do you know where I can get a base map for my set up? it will help me a lot
