Another wideband/flashpro question.
vadik_s2k
Post by vadik_s2k »
So the car is 2006 USDM S2000, I have AEM wideband connected to ELD but my tuner says this input cannot read A/F values below 12-12.2..is this true? We don't have a choice of inputs in s2000, only ELD and ECT2?
Also I'm using offset and I heard it's not gonna be accurate to datalog wideband with offset? Should I re-ground wideband to the ECU ground?
Thank you!
Re: Another wideband/flashpro question.
Do you actually have it installed yet and have you verified that it is not reading the full voltage?
vadik_s2k
Post by vadik_s2k »
yes, it is actually doesn't read anything beloq 12.14:1, just like the stock sensor doesn't read lower than 10.14:1 in the flashpro logs..
Can you post your calibration as well as a datalog showing the problem.
ek9max
Post by ek9max »
Did this ever get resolved? Mine isn't reading below 11.7. My gauge is reading 10 flat though.
antkouv
Post by antkouv »
Same issue here. With a PLX device it only reads down to 11.7. Datalog attached.
The PLX gauge shows correct values (for example 10.8-11.5)
