Is it possible to import CSV files into flashpro?
bigbadspoon
Post by bigbadspoon »
I know Flashpro can export .fpdl to .csv files, but it can't seem to load .csv files back in. Is there something I have missed, or some kind of trick people use? Basically, I'm trying to combine several datalogs into one large file so that the cells I use less often will have a better sample size to calculate averages from.
Re: Is it possible to import CSV files into flashpro?
You cannot convert them back or combine datalogs.
BWelbourn
Post by BWelbourn »
While you cannot import the .csv file(s) back into FlashPro Manager, you can combine (i.e., merge) .csv files together. I merge the .csv files together using statistical software (you can get some of these software packages for free online), and then analyze the combined data using the software. I use the analysis from the software to adjust/tune my FlashPro calibration (i.e., I essentially do all of my tuning outside of FlashPro Manager).
