Euro Type R with PRB Kpro Ecu and wideband
vesblade
Post by vesblade »
I'm planing to use PRB Kpro Ecu with wideband O2 sensor(Denso 234-9005) on UKDM Civic Type R.
Should I plug and play directly( as someone told me that he runs his car 3 years like that) or make wiring modification http://www.hondata.com/techk20-ctr-o2wiring.html ?
Re: Euro Type R with PRB Kpro Ecu and wideband
The wiring must be modified for it to work.
vesblade
Post by vesblade »
Thank you for the answer.
And after that I should use the RSX Type S (PRB) calibrations right?(Not Civic Type R European).
Maybe it's obvious but need to be sure.
correct
