Hondata with ????
NAturalDC2
Hondata with ????
Post by NAturalDC2 »
Can someone tell me if the s200 is used with the factory ecu or is it it's own ecu? I have a 00 jdm type r motor with a p73
John[/list]
NA is Best!
You will have to convert to a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html.
NAturalDC2
So that means i have to go get a OBD2-OBD1 jumper then a OBD1 ecu?
John
NA is Best!
DaX
Post by DaX »
NAturalDC2 wrote:So that means i have to go get a OBD2-OBD1 jumper then a OBD1 ecu?
John
Correct. Once you have the OBD1 ECU, the S200 blue box works in conjunction with the stock ECU. Here is a picture of my setup:
NAturalDC2
Cool. Alright thanks DaX i wasnt sure on how the system works.
NA is Best!
