Aim solo dl w/ kpro
WilsonC
Aim solo dl w/ kpro
Post by WilsonC »
Hello,
I have a aim solo dl (can +). There is a file in kmanager that needs to be edited to log data from the ecu. As stated on the aim sports website. But the file could not be found it is "kmanager.ini"
Any idea why I can't see this file? Does it even exist anymore?
Thank you any help is much appreciated.
Re: Aim solo dl w/ kpro
This does not need to be edited in the latest release of software.
WilsonC
Post by WilsonC »
Okay, after following all the instructions provided by AIM the ECU is still not sending any data to the logger. wiring is correct.
I uploaded the calibration with the solo DL on and connected to the ECU.
I transmitted the device setting with the ECU on and the DL
Any help would be much appreciated. Thank you.
From Help, About, what version of software are you using?
WilsonC
Post by WilsonC »
3.2.5.0
The K-Pro does not send a CAN signal an will not work with this. Details on the serial communications can be found at http://www.hondata.com/help/kmanager/se ... sub=serial
WilsonC
Post by WilsonC »
Really? I have purchased the component aim offers for k pro. Was told it works for k pro but I'm guessing it's not available anymore because of a software update? Can it be done?
Are you trying to communicate with a CAN signal? What settings do you have in the KManager software?
WilsonC
Post by WilsonC »
For datalogger I set it to 9600.
That's about all that I did on the setting for logging. Before we had to hang the script a little but as said before it is not required with the new update.
WilsonC
Post by WilsonC »
Yes I am trying to communicate with a can signal.
That will not work, CAN is not supported.
WilsonC
Post by WilsonC »
Is there even a way to use k pro and aim solo dl together?
That I do not know. You will have to talk to the manufacturer of the device and you may want to send them the information in our help file ( http://www.hondata.com/help/kmanager/se ... sub=serial ) to see if they can check compatibility.
