in need of a basemap for b18c1 semi built head
calderonj277
Post by calderonj277 »
i need a basemap for b18c1
stock bottom end
skunk2 throttle body 68mm
skunk2 intake manifold
skunk2 stage 2 cams
supertech springs and retainers
rc 55o injectors
header
2.5 inch piping
please need this A.S.A.P
keto06
Re: in need of a basemap for b18c1 semi built head
Post by keto06 »
Cant promise it will work, but it should get you started.
Mess with the Idle RPM and the overall fuel trim under the fuel trim tab until you get it to idle like you want. Then get it to a tuner or put a wideband on it IMMEDIATELY.
Also, are you running stock cam gears with these cams or are they dialed in?
Also what plugs are you running?
02 RSX Type S (sold)
11 TSX Tech (daily)
Hit me up for free Hondata Help. Over 4K downloads on my famous GSR Tune!
calderonj277
i have skunk2 pro series cam gears and also im using ngk vpower size 8 plug
calderonj277
thnks for the basemap but now my car idling steady at 2grand ive mess around with the fuel trim and the idle and it stays the same do ou have any idea what could it be .
keto06
Post by keto06 »
what are the cam gears dialed in at? And an 8 heat range plug? Thats cold even for that setup. Im sure youd be fine with a 7. What gap are you running?
Perhaps a vacuum leak?
What numbers have you tried for overall trim and idle?
Did you let the car warm up or was this the cold idle RPM? Any kid of warm up log?
11 TSX Tech (daily)
