1.5.5 Civic AFM Calibrations Radiator fan issue
VitViper
Post by VitViper »
When unchecking 'use second ect sensor to control fans' the fans don't seem to turn on... I'm burping my Si and the ECT is 228* with no fan activity.
Re: 1.5.5 Civic AFM Calibrations Radiator fan issue
What year and vehicle and can you post a datalog showing hte problem as well as the calibration?
VitViper
Post by VitViper »
If I must... I do not have the 228 ECT logs as I was not recording when I was burping the system, but here is idle after I had burped the car. Cal is attached as well -- even with the option unchecked the ECU is still using the second ECT sensor to toggle the fans on/off.
2011 Si
