s300 problem
anthonyb5s4
s300 problem
Post by anthonyb5s4 »
i just bought a hondata s300 and the only way i can setup a calibration is if i erase the ecu which turns the steady red light, green then i can upload it but once i shut the car off it erases nd it bogs misfires and taps out at 3k rpms
also when it does work launch contol doesnt work it just shuts down
Re: s300 problem
What is the serial number on the s300 board inside the ECU? From Help, About, what version of software are you using?
anthonyb5s4
Re: s300 problem
Spunkster wrote:What is the serial number on the s300 board inside the ECU? From Help, About, what version of software are you using?
im using the latest software (not the beta) and the serial number is 12561
Re: s300 problem
Download the most recent beta version of software and see if that will work for you.
