Traction Control software - Disabled
dantok
Post by dantok »
Hey guys,
Plugged the TC into my PC. However it keeps telling me that the module is disabled - software needs to be updated.
How do i fix this?
Re: Traction Control software - Disabled
You are probably running an older version of the traction control software. The traction control software is built into SManager/KManager/FlashProManager, so you should not run the standalone traction control software.
dantok
Post by dantok »
Yup! Got it sorted, after plugging into the KPRO software, figured out it worked fine.
The standalone was running 1.0.4.0 which was the latest, so not sure why it didn't work :(
Pantelis
Post by Pantelis »
Hi, Just installed the latest Kmanager but does not include Traction Control either under the window or the parameters tab. How can I find it?
Pls note that pc not connected to traction control module yet. So with Kpro do we connect the pc with the ECU or the traction control module to adjust the settings.
