2013 si running rich
spyder0314
Post by spyder0314 »
i datalog at wot and it seems like im running way rich. as high as 10.14. This is the factory ecu settings. My only mod is afe momentum intake and flashpro. It's in stock ecu calibrations. Not sure if this is normal or not. Thanks. Also when i check the fuel table in flashpro, i only see wot lambda adjustment low/high but not the fuel map low/high
iXtr3me
Re: 2013 si running rich
Post by iXtr3me »
My 2012 SI was also running VERY rich with just an AEM CAI on it. So rich in fact it was bogging down when the car went into Vtec because there was just too much fuel for an effecient burn. A dyno showed it to make 126 WHP up to 5,000 where it cut out.
My tuner fixed that with FlashPro though and now it seems fine. I think it may be to do with the CAI but I'm not certain. I was also up over 10, pig rich as Steve called it. After the full tune and just the CAI it's reading 190 HP on the dyno, best pull.
2012 - Honda Civic SI HFP in White
At least my basic mod's constant CEL's add a nice yellow ambiance
spyder0314
Who did you get it tuned? Dyno or etune? Did they also tune your cam and ignition or just fuel? So 190 whp with just cai and flashpro?
iXtr3me
Post by iXtr3me »
It was an actual tune on a dyno done here in Winnipeg. It was costly, I was hoping to get in the game with more left in my pocket, but the mid-range gains he tuned for for were well worth it. I really wanted a mid-range bump where the typical driving is done. He calls my tune a "hybrid tune" using AFM on all but WOT which then switches to MAP. He thinks I may be the only one around with this type of tune on a 2012 SI... yay originality!
Yes, just the CAI and Flashpro. I had a Skunk2 exhaust on it but it was FAR too loud for street driving. I had to take it off. The tune was done with factory full exhaust.
It was tuned on a DynoJet in-ground model 224xLC for your information.
spyder0314
Hey seems like we got same mode with just intake and flashpro, i can use a tune badly. Mind sharing your calibration? Im in the stateside so you'll still be the only one in canada lol.
spyder0314
So u got 190 whp with that tune nice!
spyder0314
I'm still running rich at wot no matter what map i'm running. Base map, reflash, and custom tune revision, all rich at wot. I've been told it could be a bug? Please advise. Thank you.
Jdogg
Post by Jdogg »
are you tuning with the afm or map? The afm really sucks, make sure whoever tuned it is using map fuel tables.
According to the calibration posted you are not tuned via MAP. You may want to go back to your tuner and have them retune this using MAP fuel tables.
pmorel28
Post by pmorel28 »
could someone please tell me if my car its running rich.
its a 2013 with 2012 reflash
VitViper
Post by VitViper »
pmorel28 wrote:could someone please tell me if my car its running rich.
Your car is running very poorly with that calibration.
pmorel28
Post by pmorel28 »
Ok so Etune my car with you will also eliminate knock and how this work just tell you what part i have in my car and you do the calibration tuned.
Sorry but i am new with these thing my first time tuning a car also
