Throttle FD2 in FN2 (update, fix)
eldelcivic
Post by eldelcivic »
Hi guys
I have a throttle body J35 of a FD2 and yesterday I changed OEM throttle.
Right now with the new J35, my engine is working a bit bad. When I dont push the gas, the revolutions fall slowly and bounce.
I need adjust any parameters of idle or air fuel ratio... i dont know.
how you fix this problem?
Thank everybody.
eldelcivic
Re: Throttle FD2 in FN2
Hi everybody.
i Attach my data
- Serial number: FP-SI-INT-20257
- FlashPro Manager version: the last
- Honda Civic Type R FN2 (euro)
- what sort of ECU you are using
- Modifications
Gruppem and throttle body J35.
In my datalogs no there are knocks but i think that this calibration can be better with more adjust.
I would like to give me your opinion about my calibration and advise me that I can improve and how to do.
Still I do not know much about setting a map and thank you very much any help and advice you can give me.
Regards!
Re: Throttle FD2 in FN2 (update, fix)
This probably has to do with the difference in how the throttle body is controlled. This is a common problem when swapping larger throttle bodies. It could be a leak, or it may just not be a good match for your vehicle.
eldelcivic
Hello,
thanks for replying!
I searched about this problem and in my case specifically was make the engine (sensors) to read the new values ​​and self-adjust.
I have only one question more ...
your kindness you would have to watch my data logs and tell me that I can improve and how?
I guess you have plenty to do every day, but if you find a bit of time to check my calibration I'll be very grateful!
regards
JUJU
Post by JUJU »
Made on or two changes to your map.
Try this and let me know if it feels any better
seem
Post by seem »
Hi man! You will need to re-adjust your map. I have installed the J35 in my Fn2 (Spain) as well and there is no problem.
Touge Master
Post by Touge Master »
I've maped several FN2 with J35 TB here in Spain.
Have you made the ECU relearn? Are you throwing any code?
Kouzan Racing Engineering
