After high RPM run car breaks up
crazyracing04
Post by crazyracing04 »
Engine: B18C Type R
Endyn Rollerwave 12.5:1 (81.5mm)
Brian Crower Stage 3 cams
Ferrea flat faced valves(Stock size)
Port and Polished head by RLZ
BDL 70mm TB and Edelbrock Victor X intake mani
RC550cc injectors
New Distributer, Cap, and rotor
Car has been tuned. Just not completley. After I make a full throttle run or get into the higher RPMs and let off of the throttle the car shuts off. If I try to keep it running the car breaks up bad. Once the car has been restarted it runs like nothing happened. This just recently started after having the car down to do bodywork. Any help or what I should look into next would be great.
Re: After high RPM run car breaks up
Check your grounds and anything else that was touched when the car was worked on.
