Soft limiter Anti lag
9queSt
Post by 9queSt »
i was thinking of setting
launch limiter.........5800
anit lag.................5300
fuel..........100
igniion......-20
soft limiter............5750
If I use the soft limiter with anti lag, is it more harmful to the engine then just anti lag alone?
What is the purpose of soft limiter?
Re: Soft limiter Anti lag
The soft limiter is to make the rev limit smoother and less bouncy. Antilag generates a lot of heat so you must always be careful when using it to avoid damaging turbos and other damage to the engine.
