Problem to download and upload program
menfou
Post by menfou »
Hello, I have a problem when I want to download or upload a program.
I can't use datalog,download or upload functions, but I can delete DTC error code with K-Manager, if the engine is on and I want to download the ECU program, the engine stop.
If the engine stop I think don't have USB problem.
When I download Ecu program, during 20s I can't do anything, and after I have a map with bad value.
When I upload program I have this message : " fail to upload"
The led is green, and the other red when I use download function during 2secondes.
menfou
Post by menfou »
I tried a other laptop and I have the same problem.
I am 2 laptop with USB1 not USB2.
When I download or upload a program , I listen my fuel pump.
Please go to the menu at the top and select ONLINE, then TOOLS, then click on CLEAR SECURITY. A warning may appear, go ahead and clear the security. Once you have done this, go ahead and upload the correct calibration and then you should be ready to go.
menfou
Post by menfou »
thank you , I can put my 7PSI program now :P
