k-pro can`t connect to notebook
rid11
Post by rid11 »
I had a check, I tried will be connected to k-pro through k-manager, but left nothing, the laptop doesn't see k-pro and at all doesn't see connection of the new device, but the engine is started. I tried to reinstall the driver, it is installed, but k-manager doesn't see it and in the list of devices there is no it too.
k-pro Serial#: 05009824
ecu: 37820-pnf-a04
Re: k-pro can`t connect to notebook
What shows up in the WIndows Device manager when you plug in the USB to the K-Pro?
rid11
Post by rid11 »
Nothing, windows does not see the device, on the other computer is the same situation
Please post a high resolution, in focus picture of the K-Pro board.
Where did you purchase this from?
rid11
Post by rid11 »
bought from a guy on the forum k20a.org
rid11
Post by rid11 »
ecu operating in emergency mode, revlimit 3500
With the Windows Device manager open does the screen reflesh when you plug and unplug the USB from teh K-PRo?
rid11
Post by rid11 »
no
Do any lights come on on the K-Pro board when the USB is plugged in, or when the Key is turned to the on position?
rid11
Post by rid11 »
Spunkster wrote:Do any lights come on on the K-Pro board when the USB is plugged in, or when the Key is turned to the on position?
yes, when the USB is plugged in, green lights come on, when the engine is started, lights green and red flashes
Send and email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions (include a link to this thread):
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
