Calibration Won't Upload
elmo
Post by elmo »
Greetings! I just received a calibration file from CT-Engineering for the 2012 Si SC. I placed the file in the Flash Pro folder with all the other calibration files. However when I click on the New Calibration button, it doesn't show up in the new window. If I rename it to one of the other files that show up, it still will not show up.
When I click on the open file button, then click on the CT-Engineering file, the Upload button on the Flash Pro window is grayed out and I can't load it into Flash Pro.
Flash Pro Manager version 1.4.5.0
Windows 7 Pro 64 bit.
Am I not doing something wrong or is it a corrupt file?
Thanks!
Re: Calibration Won't Upload
First download the latest FlashPro Manager version, which is current 1.5.6.
Check that the USB drivers are installed and that FlashPro Manager shows all ticks on the bottom left.
Open the CT calibration using the File -> Open menu.
elmo
Post by elmo »
Upgraded to 1.5.6.0 That seems to have done the trick when I go to open file. The upload button is no longer grayed out and I can now load the calibration into Flash Pro. However, I still can't see it when clicking on New Calibration though. Thanks for the help!
It will not show up when you click on new calibratoiin as that is only for built in calibrations.
